J-n-C Project Cars
Project Moff - 600 BHP R33 GTS-t Race Car
13 years 6 months ago #34893
by moff
Project Moff - 600 BHP R33 GTS-t Race Car was created by moff
13 years 6 months ago #34895
.......Awesome build there mate..........
Replied by Mr. G on topic Project Moff - 600 BHP R33 GTS-t Race Car
13 years 6 months ago #34899
by moff
Replied by moff on topic Project Moff - 600 BHP R33 GTS-t Race Car
Time to Trial fit new rear arches ready for 11J Rims on the back...
More info here .... www.theprojectmoff.co.uk/12-march-2013.5483603.cms
13 years 6 months ago #34907
............Looking Good
13 years 6 months ago #34909
by moff
Updated spec list ..
Engine
•RB26 Red painted engine (from an R32 GTR)
•Garret 4094R Turbo (Oil and Water Cooled)
•HKS F Con Pro Gold Ecu (version 3.2)
•Wossner Pistons
•PEC Rods
•ACL Race Bearings
•Stage 1 Abbey Motorsport modified Head
•HKS Camshaft 264 Duration - 10.0mm Lift - Inlet
•HKS Camshafts 272 Duration -10.2mm Lift - Exhaust.
•Balanced Crank, flywheel, front pulley
•Top Mount Manifold
•Denso 720cc injectors
•HKS Oil pump
•N1 Water Pump
•HKS Gaskets and seals
•HKS Triple plate clutch
•Greddy External wastegate
•Trust 100mm FMIC
•Mocal 34 Row Oil Cooler
•50mm Japspeed Radiator
•Nismo Fuel Pump
•Splitfire Coil Packs
•Rips modified GTR sump, with diff removed, welded, extended and baffled
•Cold start system removed
•Cabin heating systems removed from engine
•Tomei Fuel Rail
•R34 GTR Engine Loom
•Greddy EGT Gauge
•Greddy Profec B Boost controller
•HKS Hard Pipe Kit
•HKS Induction Kit
•Air Con Removed
•Carbon Canistor Removed
•RB25DET Gearbox
•Front & Rear Strut brace
Exhaust
•Japspeed De-Cat
•Japspeed Turbo Elbow
•V-Band 80mm Downpipe
•Japspeed spec 1 cat back exhaust
Drivetrain
•Heavy Shockproof Gear Oil
•Silkolene Diff Oil
•Nismo Pro S 1.5 Way Rear Diff with extended cooling fins
•HKS Triple plate Clutch
Suspension
•Driftworks Rear Camber and Caster Arms
•Cusco Front Camber Arms
•Polished Stainless Hicas Lock Bar
•Driftworks Front Tie Rods
•Tein Track Rod Ends
•Tein Track Rods
•Poly Subframe Bushes
•Driftworks Rear Traction Arms
•Ohlin Coilovers (Rebuilt to full track spec)
Exterior
•Full Respray (coming soon)
•Nismo Bodykit
•Custom front Splitter
•Carbon Nismo 'B' Pillars
•Custom made Carbon Kevlar bonnet
•Custom Carbon Kevlar wider front wings
•Carbon Rear Boot
•Carbon Rear adjustable Spolier
•Custom Sand Blasted, etched and powder Coated front and rear subframes
•Dual HID's 600k 55w. Main and Dipped Beam
Interior
•Tinted Windows
•Corbeau Evolution Carbon Kevlar Drivers Seat
•Aftermarket Racing Steering Wheel
•Apexi Dual Turbo timer
•Greddy Profec B2 Boost Controller
•Stripped Interior
•HKS Boost Guage
•2 x 3" 4 Point EJS Racing Harnesses
•Andy Robinson FIA Approved 7 point Roll Cage with Door Bars
•Greddy 60mm EGT Gauge
•Greddy 60mm Oil temp Guage
•Greddy 60mm Oil pressure Guage
•Stack Water Temp Gauge
•Carbon Door Cards
Brakes
•Nismo Steel Brake lines
•Stoptech 355mm Front and Rear Discs with Aluminium Hubs
•Stoptech 6 Pot Front Calipers
•Stoptech 4 Pot Rear Calipers
•DS3000 Pads
•Custom Moff made brake stopper
•RBF600 Racing Brake Fluid
Wheels & Tyres
•18 x 11J Rota MXR Rear
•18 x 10J Rota MXR Front
•Toyo 888's 315/30/18 Rear
•Toyo 888's 265/35/18 Fronts
Engine
•Wossner Pistons
•PEC Rods
•ACL Race Bearings
•Top Mount Manifold
•HKS Oil pump
•N1 Water Pump
•Trust 100mm FMIC
•Nismo Fuel Pump
•Tomei Fuel Rail
•Greddy EGT Gauge
•HKS Hard Pipe Kit
•HKS Induction Kit
•Air Con Removed
•RB25DET Gearbox
Exhaust
•Japspeed De-Cat
Drivetrain
•Silkolene Diff Oil
Suspension
•Tein Track Rods
Exterior
•Nismo Bodykit
•Carbon Rear Boot
Interior
•Tinted Windows
•Stripped Interior
•HKS Boost Guage
•Carbon Door Cards
Brakes
•DS3000 Pads
Wheels & Tyres
13 years 6 months ago #34910
by moff
After we were happy with the mock up of the new rear wider arches, its was time to make a start with fitting...
Out came the Angle grinder
This is the car lowered back to the floor, as you can see we have plenty of room. This is an 11J rear wheel
The next step will be to make up a lip for the new rear arch to sit on, as well as to join the 2 skins back together...
Full details can be read on the site of course... www.theprojectmoff.co.uk/19-march-2013.5483995.cms
Lots more to come...
13 years 5 months ago #34914
by moff
Now that we had cut the arches out to allow for more room, we had to weld the 2 skins back together.
This would do a number of things :
Put strength back into the arches
Stop water getting back up into the arches and rusting
Give us a mounting point for the new arches
We started by tacking pices of metal in place.
More info on the blog... Project Moff Blog
Project Moff on Facebook
Loads more to come...
13 years 5 months ago #34915
Big project mate..............some nice work there
13 years 5 months ago #34917
by moff
some good Progress
New rear arches are on .. The Wheels on the back, don't forget are 11J Wide !!!
Next the caris of To Abbey Motorsport to go on their Dyna Pack Dyno, some suspension work, and Race Prep
www.theprojectmoff.co.uk/12-april-2013.5484423.cms
Things are now really starting to hot up...
13 years 5 months ago #34921
by moff
Here are some photos of the new rear arches. Believe it or not, we actually sprayed the rear arches using nothing more than black spray cans... This is only temporary until the car goes in for a respray.
The wheels on the car are spare wheels until the race wheels are fitted..
The Car is now off to Abbey Motorsport in Surrey, who will be putting the car on their Dynapack Dyno, setting up the Suspension and some other Race prep..
More details on the blog.. www.theprojectmoff.co.uk/25-april---arch...torsport.5484935.cms
13 years 5 months ago #34931
by moff
Project Moff is now at www.abbeymotorsport.co.uk.
After a quick look over the car, they noticed the exhaust manifold is cracked
and urgently need of repair. Its going to be removed and hopefully welded up.
They are extremely busy, but have managed to find the time for this
additional work, great stuff...
More updates soon....
13 years 5 months ago #34936
by moff
The car is very nearly all set to go on the Dyno in the next day or 2 for a
tweak at Abbey Motorsport on their Dynapack Dyno.
Looking forward to seeing what the car produces...
Should start with a 5 in the BHP figure..
13 years 5 months ago #34940
by moff
Wow, huge thank sto the guys at Abbey Motorsport...
Project Moff managed 605 BHP at the hubs, which is more power than before, and at less boooooost...
Great results, dyno charts to follow...
RWD only, this is going to be fun... !!!!
13 years 5 months ago #34942
by moff
Here are the dyno results...
The previous time Mark @ Abbey Motorsport had the car on the Dyno, at 1.5 Bar, the car was producing 594 BHP ATH.
We the changes and improvements we made, he managed to bring the boost in a little earlier, and at 1.4 Bar,
we now have 605 BHP ATH, and what should be a more driveable car too...
Here is the Dyno Graph
For the other dyno sheets, and a comparison of the last ones, for you real geeks, please see :
www.theprojectmoff.co.uk/14-may-2013---a...-results.5487807.cms
Time to create page: 0.098 seconds
J-n-C Project Cars
- Project Moff - 600 BHP R33 GTS-t Race Car
